Removing these trim panels
Impossible-LOL
You have to remove all of the trim in the back. There are several torx screws that need to come out. Remove the little Airbag emblems to expose torx. There is also a torx inside the hanger for the screen. There are torx along the bottom edge of the panel you are removing. Once you are pretty sure you have all of the torx out then start pulling and prying. You have to remove the center cover around the top rear cargo light first, then everything else just works it’s way down. Go to Harbor Freight and get their best interior removal tools. I have done this several times. As long as you get all the torx out it is not that bad if you have good tools. I would search YouTube as well. There are videos for almost everything you can do to a Cayenne.
dsp5500 (03-20-2023)
There is a good post on pelicanparts forum about. I will try and find it. Also here about trailer wiring if you search. They both had good photos and step by step if I remember correctly.
