Most correct AWD transfer case control unit?
2005 955, 3.2. Auto
I didn't have the infamous "clunk" but what I had was probably more entertaining. Cruising at highway speeds, the cruise control light would flicker and the engine would act like it was misfiring. I finally figured out the engine was NOT misfiring, no signal from the brakes, no issue with the pedal or throttle signals, but when it acted up it would fall flat on its face. Finally figured out the transfer case was switching between "high range" and "low range" on its own. Unplugged the module and it was healed.
So I'm shopping for a module and can't figure out which part number I should be looking for. The TSB says my old module should be a 955.618.023.10 and I should upgrade to a 955.618.023.11. My module doesn't have a 955- number on it though. It just has: 0AD927755AD
When I look up 0AD927755AD the ebay results come back to 955.618.023.05. Is that accurate? The 955.618.023.11 is giving me a 0AD927755M. Is that accurate? TIA!
