Tapping Into Fuse Panel
One is to attach a male 0.250 Faston tab onto a wire and poke it into an unused, powered fuse contact. This has been shown in several topics in this forum. With this technique, exposed wires are seen, once the fuse cover has been removed.
The other technique is to purchase the fuse contact from Porsche. With this technique an unused fuse location is still selected, but this fuse contact is attached to the wire. This wire assembly is then inserted into the BACK of the fuse panel, with the rest of the wires. A fuse is inserted, to apply power to this new wire / fuse contact assembly.
The attached image shows the 999 650 356 12 fuse contact, available from Porsche. The image shows the wire is retained by a dual crimp, one on the conductor, one retaining the insulation.
