Dual personality
Old 01-15-2023 | 01:04 PM
TomF's Avatar
TomF
Originally Posted by Ob917
The turbo S intercoolers are bigger, I’m not sure if that’s the difference or not. I’ve trimmed the plastic around the intercoolers but it still rubs when the tires are turned.
My wheels are the stock 20” wheels I don’t remember the offsets. I also needed spacers for the front to give some extra space to clear the upper balljoint (15mm).
I don’t have the lengths on my arms, I should keep track of that stuff. It took quite a few small adjustments to get them right and the car level.
Thanks again for posting the lowering links info above. What links are you using for lifting your P!G?
Old 01-15-2023 | 08:43 PM
Ob917's Avatar
Ob917
same ones, just adjusted in the other way🤘🏻
Old 01-15-2023 | 11:04 PM
TomF's Avatar
TomF
Got it. I didn't know whether they could be adjusted that short. By my math, they need to be shortened about 7.6+mm to achieve the 2 inch lift. Cheers
Old 01-16-2023 | 01:23 PM
Ob917's Avatar
Ob917
I took the lock nuts out and trimmed the threaded rod to gain an extra 1/2” or so of range with the arms. Rough measurements
Old 01-17-2023 | 06:16 AM
Andrew_955's Avatar
Andrew_955
My car has the E81 kit which includes the Turbo S intercoolers.
This all but confirms my suspicions about offset being critical to clearing big tyres on a turbo pig. I bet if you drop down to a 5mm spacer it would clear or be very close to clearing the intercoolers. I chose to go for no spacer, trimmed the excess BJ threads and chamfered the nut. No contact there or at the coolers. I drive it in the low setting all the time, no scrub. Lots of pics on my build thread if it helps.
Old 01-17-2023 | 02:51 PM
Ob917's Avatar
Ob917
I ran them with no spacers, the rubbing was worse set up like that.
Old 01-20-2023 | 01:41 AM
Crozzer's Avatar
Crozzer
Hmmm… you got more intercooler rubbing with oem offset, without spacers? Or did you mean rubbing on the control arm nut/bolt?
Old 01-20-2023 | 02:15 AM
Ob917's Avatar
Ob917
on the intercoolers.
Old 01-20-2023 | 07:17 AM
Andrew_955's Avatar
Andrew_955
Interesting, I wonder why the same size/model tyre clears on my car but not yours?
You said you trimmed the plastic, whereabouts did it rub with no spacer? If it ain't core or end tank, trim it!
Did it clear the BJ with no spacer?
I R confused.
Old 01-20-2023 | 09:18 AM
Crozzer's Avatar
Crozzer
I R confused.
Me R too.
adding a spacer moves the wheel out, where it swings a bigger arc. Removing the spacer should tick it in…
is it possible that for your test, you used different suspension heights or tire width/height?
at any rate, offset is my issue. Still looking for 18” with factory offset that for over the big brakes.
Old 01-20-2023 | 11:13 AM
Ob917's Avatar
Ob917
I don’t want to trim more, what I should do is move the intercoolers forward.
Not sure why mine does and yours doesn’t. Maybe a castor setting? Maybe the particular tire, Falken Wild peak? It did clear the ball joint just barely without the spacer. The rubbing only bugs me when I back up and turn in any setting lower than the normal setting.
Old 01-20-2023 | 11:17 AM
Ob917's Avatar
Ob917
Me R too.
18” wheels will not fit over the brakes on this car
no matter the offset. I wish they would. I loved how my last S looked with 18s.
Old 01-20-2023 | 12:07 PM
Ob917's Avatar
Ob917
So thankful for loading level
Old 01-20-2023 | 04:52 PM
Andrew_955's Avatar
Andrew_955
Ok, your 20" OEM wheels might have more offset than my OEM Sport Techno 20's, I couldn't bolt the wheel on at all on without trimming the excess BJ threads. Falken wildpeaks here too.
Just checked and my front rims are ET60. 9" wide.
If it only scrubs in reverse and on the low setting, you must be damn close to having it all clear...
Quick Reply: Dual personality
