Recently I had a problem opening the rear hatch and the rear window. I manually opened the rear window and everything works but it stops working as soon as it's closed... I tested it by locking the lock mechanism with the window open and it still doesn't work. Is there anyway to test the micro switch? The reason I ask is that the window open light turns off when the window is closed, It's so confusing...lol
