Need help identifying a part after removing manifold
I removed my manifold,to replace the T fittings, however, I noticed this connection that I don't see any tubes/hoses/lines from the manifold or engine that connects to it. Does anyone know if something is supposed to connect to this? I attached a pic of the connector and of a pic of the back of the engine, which I think is the correct hose that connects to it.
Here is the connector
This is the hose that I think connects to it, but not sure and I don't see this hose anywhere on the manifold or engine.
Thank you!
Thank you!
Yes there is supposed to be a hose there. It connects to the corrugated hose that links the two valve covers, next to the fitting on the passenger's side valve cover.
It's part# 948-107-215-52.
The hose includes the plastic "T" fitting behind the engine, which is darn near impossible to remove. I bought a metal T fitting:
https://belmetric.com/rubber-hose-re...VC9-10%2F7-8TM
which is not quite the correct size but close enough that it can be clamped onto the two horizontal hoses with worm clamps.
The I used a piece of fuel line like the picture of the removed engine you posted to attach the line leading to the valve covers.
