2006 4.5 Cayenne S
Old 11-10-2022 | 10:17 AM
Hotruck's Avatar
Hotruck
Default 2006 4.5 Cayenne S
My 06' Cayenne S, hard cranked and sometimes just stalled while cold idling. Check Engine light is on. The initial codes showed faulty Crankshaft Sensor AND Crankshaft Position Sensor. I purchased the parts and my mechanic installed (a Camshaft sensor (2), one for each engine bank), and the Crank Sensor. Trunk runs a little better, but still cranks hard and erratic. Check Engine light still on.
Mechanic says when this happens it usually indicates a bad Timing Chain. I've dumped $$$ into these sensors and labor. How can I be sure this issue is the Timing Chain? Any advice would be appreciated.
Hotruck
Old 11-10-2022 | 11:05 AM
phatz's Avatar
phatz
6 years ago it was at 100000 miles ...and today?
Old 11-10-2022 | 11:15 AM
Hotruck's Avatar
Hotruck
127,000 miles
Old 11-10-2022 | 11:37 AM
957austin's Avatar
957austin
The camshaft deviation parameters will tell you how far out of time each is, and consequently how much the timing chain and guides are worn. I would be skeptical of a mechanic who didn't check this before condemning the timing chain.
The following 2 users liked this post by 957austin:
jAndrewH (11-11-2022), phatz (11-10-2022)
Old 11-18-2022 | 02:18 PM
Hotruck's Avatar
Hotruck
I posted this below in a new thread. I'd forgotten you and I had chatted, but yea this Porshe specialty shop gave me a print of why they are diagnosing the issue as a failed Timing Chain (he's saying it has loosened over time. It runs... but poorly. I don't have the insight to refute any of this. It certainly acts like a timing problem. Anyway, just thought I'd let you know from our previous conversation. I've towed it back to my driveway. I stumped...
Hotruck
________________________________________________________________________ ________________________________________________________________________ __
Well, it's confirmed, my 06' needs a Timing Chain replacement (after a basic and full diagnostic tests). I have a different mechanic that will install the timing kit for $1500 labor (which is about half normal labor charges). The problem is... There is no Timing Chain set or kit for these Cayennes! I searched this planet, and all parts must be purchased individually. OEM parts for the Timing Chain parts and components comes to around $4000-$5000.
Can anyone shed any light on this?... is this typical of Cayennes V8 It has 130K.
Hotruck
Old 11-18-2022 | 05:39 PM
theprf's Avatar
theprf
Loosen the cam sprocket bolts. Reset the cam timing. Tighten the cam sprocket bolts. Done.
Quick Reply: 2006 4.5 Cayenne S
