ABS Module Replacement and Coding?
Old Sep 10, 2022 | 04:07 PM
superman22x's Avatar
superman22x
Default ABS Module Replacement and Coding?
I have a 2005 CTT, and the ABS module/controller seems to be bad. Went through a bunch of diagnostics and the only code seems to point to an internal controller fault. Code is 0538, reference voltage. I bought a used one on eBay that has the exact part number. But I understand I will need to code it to match. Can the VCDS tool do this? I think using VCDS involves some minor wiring. I have the Foxwell tool, but I don't think it has the ability to code a module.
Thanks!
