Cayenne 955 2003 p0344 and much more
Old 07-10-2022 | 06:29 PM
Nikthegreek22's Avatar
Nikthegreek22
Default Cayenne 955 2003 p0344 and much more
2003 Porsche Cayenne s 4.5
Hello , I just bought a new obd and i get this codes
P0344 camshaft sensor 1
p0016 crankshaft position vis a vis intake camshaft bank 1.
p0441 fuel tank ventilation system
P1525 vehicle electrical system voltage via main relay
p0491 secondary air system bank 1
p0492 secondary air system bank 2
p0600 serial communication link
p0300 random multiple misfire detected
p0303 misfire cylinder 3.
p1614 no communication with steersteer. Wh. Electronics control unit (can drive).
p1605 communication with all wheel drive control unit
p1606 communication psm control unit.
so these are my faults 🤣😂🤣
The cars runs but idle rough like 800 rpm I don't know and also doesn't go full gas only If I do kick down
Also started to eat a lot of gasoline it took 76 liters to do 293 kmh thats too bad.
so now i cleared the faults and for now its only shows these P0344 camshaft sensor 1
but I want to know all of them some. They told me they are from. Low battery because I don't use too much the car and the other ones didn't show up now because I start to use it and the batteries are good I don't know I drive it one day a week. Sorry for. My. Bad English
Old 07-10-2022 | 07:49 PM
reyxlp's Avatar
reyxlp
Low battery can cause a bunch of seemingly unrelated issues, warning lights and fault codes.
Make sure the battery is in good health first and fully charged before you start troubleshooting anything else.
If you won't drive it often, consider hooking it up to a battery tender while it sits, if you can.
Old 07-10-2022 | 07:53 PM
Nikthegreek22
my 2 batteries are new like 1 month new but again in have the other 3 issues when in use the car a lot
Old 07-25-2022 | 12:19 PM
Nikthegreek22
Somebody to help?
Quick Reply: Cayenne 955 2003 p0344 and much more
