Headlight ballast programming confirmed!
I can confirm that the ballasts don’t need to be matching part numbers!
my vehicle currently has two different ballasts ending in part numbers .00 and .02
whats important that they are oem (made by hella) and need to match sticker design.. so if your has half yellow sticker, they must both be half yellow sticker!
a half yellow ballast sticker ballast and a full white sticker ballast (even if same part number) will still display an error on your cluster!
Ballast still needs to be programmed with PIWIS
dont believe anything else about the ballasts needing to be matching part numbers.
The following 4 users liked this post by Caliguy:
