2005 3.2 crank sensor help
Hello
i was wondering if anyone can help me
i need the specs for the crank sensor
what are the reading supposed to be for a good sensor with a multimeter?
what pins on connector do i use for taking readings?
my issue is that car cranks but won't start
When i checked with scan tool got codes for camshaft sensors and thats after i replaced them.
Can i bad crankshaft sensor cause the cam sensors to read faulty?
also other then dealer what other brand is good for a crank sensor.
thanks
thanks
