Cayenne (2005) headlight replacements
Old Feb 12, 2022 | 04:58 PM
rusputtin74's Avatar
rusputtin74
Default Cayenne (2005) headlight replacements
Hey Porsche experts!
I think I need to change both my headlights on my 2005 Cayenne. My question to you guys:
- Do u recommend also changing the cables behind the headlight assembly?
- What would be a reasonable cost to replace the light assembly and the cables behind it?
- Do you recommend any particular shops in ATLANTA that be good/fair w/ their pricing?
Please let me know. I'll highly appreciate it.
I'm considering these lights, but if you have some other recommendations, please let me know also.
https://www.autohausaz.com/pn/VL-95563115351 (left)
https://www.autohausaz.com/pn/VL-95563115451 (right)
Thank you MUCH in advance.
- Abim
Old Feb 12, 2022 | 08:02 PM
CTTS520's Avatar
CTTS520
Those are the same lights that I bought as replacements. No complaints. Seem to be very high quality. My wire harnesses were fine so I did not replace them.
Old Feb 12, 2022 | 08:35 PM
rusputtin74
I don't know if my wire harness is bad or not, but i thought while I open it, should I consider replacing that also...
Did u do it on your own or did u take it any shop? Any shop recommendation?
Old Feb 13, 2022 | 11:43 AM
phatz's Avatar
phatz
Veteran: Navy
https://www.google.com/search?as_q=i...filetype=&tbs=
Old Feb 13, 2022 | 05:08 PM
CTTS520's Avatar
CTTS520
Easy job. Did it myself. Plan on paying for 1-2 hours labor at a shop.
Old Mar 31, 2022 | 09:57 AM
rusputtin74
I finally got the headlight replaced with whole assembly. Apparently below the assembly there is a piece that holds the lights in place and mine just worn out; so, lights don't stay locked in the same place. As a result of that, sometimes the light doesn't come on. Does anyone know what is the piece called and do u have to just replace a small piece or the whole thing that keeps the lights in place?
Thanks experts.
Old Mar 31, 2022 | 08:42 PM
BrianC72gt's Avatar
BrianC72gt
I'm late to the party, but If you are trying to save a few bucks, you can insulate the crumbled wiring on the original lights with marine heatshrink.
Three issues with these lights. 1) The short harness - about 6 inches long from the inner fenderwell to the headlight housing goes bad; 2) The insulation on the wires inside the headlight crumbles and, eventually, 3) the igniters for the HID bulbs go bad.
DIY Dan has all three covered in a series of videos.
