E81 Adventure Wagon
Old 05-10-2023, 11:34 PM
  #31
TomF
TomF's Avatar
Originally Posted by Andrew_955
We're back in Melbourne now, Cayenne performed flawlessly on the trip. Never got stuck anywhere, no CEL's, no roadside repairs needed in just over 5000km of driving which included some incredibly rough roads in very hot and remote parts of the country.
​​​​​​Looking forward to picking her up from the freight depot in a few weeks.
Trip report to come when I have a spare minute.
Awesome! Looking forward to hearing more about your fantastic adventures.
Crozzer (05-17-2023)
Old 03-01-2024, 10:11 PM
  #32
Andrew_955
Andrew_955's Avatar
And now it's a baby hauler!
Back seat is starting to get pretty full...
Car continues to run great and be very reliable. No breakdowns or anything to fix yet in 2+ years of ownership. So glad I bought such a well looked after example.
After the big trip I did an oil/filter change and blew out the air filters. I also did plugs and coils as preventative maintenance but really it was unnecessary. The plugs were ok and the coils looked nearly new. I'd already bought replacements so I fitted them but kept the old ones for spares. Bit of a waste of money but at least I know they are new and will be good for years to come.
A couple of minor niggles - I noticed a small patch of clear coat peeling on the RH rear door not long after I bought it which has now grown slightly and been joined by a small one on the nose cone. Hopefully they don't grow too much and no more pop up.
At one point I left it parked for ~3 weeks, nose facing downhill. On startup I had a faint but worrying engine rattle for about 30 seconds - I was terrified bore scoring may have struck but that was 3 months ago and it's been silent since. Crossing my fingers it was a once off issue and now try to not park it nose down if it's not going to be driven for an extended period.
My unorthodox dual battery setup which sees the main AGM battery constantly being trickled charged by the lithium aux works great, never had any slow starts or low voltage issues even if I don't drive the Cayenne for a few weeks.
Trip report coming... one day, when I have time to go through all the photos and do a write-up.
The following 2 users liked this post by Andrew_955:
Gvh911 (04-02-2024), SuperG$ (03-02-2024)
Old 07-26-2024, 07:42 AM
  #33
Andrew_955
Andrew_955's Avatar
Did a service on the old girl tonight as she just ticked over 240,000km
Oil/filter/drain intercooler hose (maybe 30ml came out from here)
Changed a brake light that's been out for a couple of weeks
Topped up washer fluid
Nothing else to fix, she's been running like a charm as always.
I busted out the VCDS cable to try to reset the "Service now" reminder on the dash so i can once again join the "Error Free Cayenne Club" however i wasnt able to connect to Module 17 Instrument Cluster. VCDS auto scan worked but it wasn't able to connect via CAN and threw up a few odd faults. No CEL's or faults on the dash apart from "Service now"
Here's my auto scan results. Do i have a CANBUS issue? Any ideas on how to recify or at least reset the "Service now" reminder?
Friday,26,July,2024,20:16:37:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WP1ZZZ9PZ6LA80729 License Plate:
Chassis Type: 9P (9P - Porsche Cayenne)
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 03 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Address 01: Engine Labels: None
Part No SW: 8TE 4AS K20 000 HW: Hardware No
Component: 0041850144IE8TE4G 20180
Coding: 0001133
Shop #: WSC 66565 257 00032
VCID: 56A3335FE207543FC5-5178
VINID: 9E006AAAA260A867112001C224FBA9D6BE
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 CB
Component: AL 750 6A 0606
Coding: 0012328
Shop #: WSC 128452 000 00000
VCID: 70EF65C760A31A0F3F-5178
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0021766
VCID: 3D718CF36071A767E4-8068
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 HW: 5WK 470 22
Component: 0H Kessy 6700
Revision: 67005514 Serial number: VWZ3Z0E3377112
Coding: 0704673
Shop #: WSC 31414 000 00000
VCID: 64C71997A35BB6AF4B-8030
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77FD5EDB02CD4D37FE-8022
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7L5 907 044 AT
Component: Klima - SG 2+2 4021
Coding: 0000030
VCID: 0501241348212FA7FC-8050
Subsystem 1 - Part No: 7L5 907 049 AH
Component: Klima - SG FOND 0306
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
008 - Implausible Signal
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L5 937 049 D
Component: 3002
Coding: 0106236
VCID: 3C7781F77B6BAE6FD3-8068
2 Faults Found:
00907 - Intervention load Management
000 - -
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 10 Airbag 8.4E+ H10 0953
Coding: 0012592
VCID: 25414493E8E10FA79C-8070
Address 16: Steering wheel Labels: None
Part No: 7L5 953 549 D
Component: Lenksäulenmodul 1701
Coding: 0001312
VCID: 3F8DF6FB6A7DB577F6-806A
Address 19: CAN Gateway Labels: None
Part No: 7L5 907 530 A
Component: Gateway CAN/CAN E1 1200
Serial number: ÿÿÿÿÿÿÿÿÿÿ
VCID: 3169A0C3AC29530770-8064
6 Faults Found:
00532 - Supply Voltage B+
001 - Upper Limit Exceeded - Intermittent
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication - Intermittent
00459 - Control Module for Display and Input; Front (J523)
01315 - Transmission Control Module
01310 - Level Control System Control Module (J197)
00471 - Control Module for Elect. Regulated Dampers (J250)
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L5 907 553
Component: LUFTFDR.-CDC- 3C3P1 3282
Coding: 0015511
VCID: 75E154D318C13F27EC-8020
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
Coding: 0021766
Address 65: Tire Pressure Labels: None
Part No: 7L5 907 273
Component: Reifendruckueberw. X120
Coding: 0331313
Shop #: WSC 00019 147 00001
VCID: 74E769D713BB262FDB-8020
Address 69: Trailer Labels: 7L0-907-383-1D9.lbl
Part No SW: 7L0 907 383 M HW: 7L0 907 383 M
Component: J345 Anhaenger 0080
Revision: 4C008002 Serial number: 00000161342726
Coding: 0016387
Shop #: WSC 66304 001 24584
VCID: 3E738BFF6D77BC7FFD-806A
2 Faults Found:
02562 - Trailer; Brake Lamps
011 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
00335 - Control Circuit Taillights
010 - Open or Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 40
Time Indication: 0
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 41 Einparkhilfe 1107
VCID: 397998E374599B47C8-806C
1 Fault Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
End-------------------------(Elapsed Time: 09:31)--------------------------
Trailer faults - all my trailers have LED lights and always throw up a dash error
Park assist works fine
01520 - Rain and Light Recognition Sensor (G397) - i do feel as though the headlights "auto on" most of the time, even during the day
00907 - Intervention load Management - what is this?
Other systems with implausible signal all seem to work fine - HVAC, level control, transmission, dampers etc
So overall fairly healthy but why can't i connect to the Instrument Cluster and why all the implausible signals?
Quick Reply: E81 Adventure Wagon
