HELP: Airbag harness clip under passenger seat 955
Hoping someone can help. I loosened the seat to replace a module under the seat. I did not realize the plastic harness clip came loose under the seat. When my wife moved the seat all the way back, it apparently tugged the loose cable and disconnected the airbag connector plus I get a check passenger seat settings. I plugged the connector back in and reset the code for the air bag. I need to know how to attach the clip on the pic below so that it does not tug or interfere with any movement of the passenger seat.
I was hoping someone would know where this plastic harness clip attaches to?? Under the seat? or on the side of the seat rail? I can't find any pics on the web.
Thanks in advance! This is the view from the front passenger seat underneath. You can see the harness for the airbag going towards the passenger door. This is the clip on the harness that came loose next to the seat rail closest to the door.
