panoramic roof
Old 10-08-2021 | 08:06 PM
Anders Flodin's Avatar
Anders Flodin
Default panoramic roof
HI,
I did a search but could not find any info on this. The WSM explains how to remove the front 3 panels of the panoramic roof but does not say anything about the forth panel, the fixed one in the rear of the roof. Is it removable or glued in place or integral to the whole frame? Reason asking is that there is a crack in that panel on a cayenne that I am looking at buying. I have seen other panels (1-3) on ebay for 500 bucks a piece so just wondering if possible to replace or if whole roof has to be taken out, frames and all.
Thanks,
A
Old 10-10-2021 | 04:46 PM
lkraav's Avatar
lkraav
Originally Posted by Anders Flodin
HI,
Thanks, A
I have a 955 with panel 4 crack in it. Everything I've read about it points to "let it be" - prohibitively expensive to fix.
Old 10-10-2021 | 06:05 PM
Anders Flodin
Default Thanks
Thanks,
I have seen other cars with panoramic roofs that just changes the panel at the auto-glass shop, YT videos indicate that it is straight forward process as long as the pane is glued, and cost wise it should be the same as a getting a new front wind shield, 500 buck:ish.
But advice taken, there are no leaks, it is just cosmetic.
Quick Reply: panoramic roof
