removing rear seat
analyst
It is a 10 mm triple square, not torx. The drive tools are shown individually, or as a set here: http://www.mytoolstore.com/sk/sk03093.html. There is another source for a less expensive set, that could be located using the search function.
analyst
It would be useful to have some blue, medium-strength, Loctite on-hand when replacing the seat bolts. The factory uses this to maintain torque and to prevent corrosion.
