Help
Occasionally when I drive my cayenne, the gear switches from automatic mode to manual mode by itself. I’m 100% sure I did not accidentally switch to manual mode. Has anyone experienced this problem?
Jamy,
I believe that there is an auto kick down into manual first gear when the car is cold. The manual light will show for a few moments, then revert to auto. I have been told that it has to do w/ the cat. converter -- getting it sufficiently warmed up.
Craig
Craig
I have also inadvertently hit the steering wheel button on occasion, especially when turning. Took me awhile to figure it out until I read about someone else doing the same thing.
Pay attention to this, and you will probably find that this is the problem.
Good luck!
Good luck!
