Durametric Engine Output Test
I have a 2005 Turbo and ran the Engine Output Test in the Durametric 6.5 software. Unfortunately, the Output Test doesn't tell you what actuator it is activating. Is there a sequenced list of actuators anywhere?
This is what I have figured out so far about the engine output test sequence:
START
n75 tank vent valve(front left intake clicking)
(no sound on my car)?
right secondary air pump (motor running)
Boost Pressure Control Solenoid (front right intake)
Behind fuel door (solenoid clicking)
Ambient Air Solenoid (back left intake)
Vacuum Pump (right side firewall motor running)
fuel pump? - air compressor? (back under motor running)
Left Secondary pump (motor running)
Fuel pump? (back under car motor running)
Left cooling fan running
Right cooling fan running
Aux Cooling Pump (in left front fender motor running quietly)
DONE
START
DONE
