Lower Control Arm Replacement
Old 06-08-2020 | 07:22 PM
jgtime's Avatar
jgtime
Default Lower Control Arm Replacement
Up next on the list is a front suspension refresh. I just have one question regarding the eccentric bolt, nut and washer. All my previous research, which includes DIY Dans excellent video , is the marking of the bolts with the subframe prior to removal. I do understand an alignment will be done right after I complete the refresh. My question is I cannot mark the bolts , nuts and washers prior to removal as I will be replacing everything because they are so rusted. Will a guesstimate suffice if the alignment shop is about 2 miles away?
Old 06-08-2020 | 07:38 PM
jeff spahn's Avatar
jeff spahn
Mark the old bolt and the frame. Transfer the marks to the new bolt. This will get you by. Remember! Only turn the nut not the bolt!
Old 06-08-2020 | 07:40 PM
jgtime's Avatar
jgtime
Thank you. Jeff
Quick Reply: Lower Control Arm Replacement
