Doing some work over the holiday and replacing the water pump, thermostat, belt, idlers etc.. this weekend. Firstly the plastic radiator hose connectors with the metal clips are of the devil. Secondly after draining the fluid I thought someone had put the orange dex-cool stuff in, but after scooping it up in a clear container it looks like the proper pink coolant. Thoughts? Did the PO top it off with orange, or just an optical illusion?
Apparently there is a Purple death but IDK what it goes with.
FWIW my local Advance has Pink death by Zerex as a gallon premix 50/50 ~$20. If you want concentrated try eEuroparts or FCP Euro, usually $25-$30 a gallon.
Really if you are doing a full flush, put whatever you want in there. IIRC Zerex G05 and even DexCool meet the US phosphate free guidelines. Remember that Pink/Purple death is because Euro water sucks differently than US water... Which is further confusing because you should be mixing with distilled water anyway! IMO DexCool gets a bad wrap because garden hose top ups vs distilled water.
