cable broken between altenator and battery
Hello,
I'm wondering I can't find a post about broken cables.
At my cayenne S 2008 I discovered first an issue at a cable to the e-box in the front. I replaced it, Followed by lot scratches on the hands...
The cable was not complete separated, but when you wobbled, the voltage in the e-box fluctuated a little. So i think the resistance value has fluctuated.
Obviously a second cable is also broken. The cable between the alternator and the battery, has the same issue and the resistance value fluctuates.
I found on the wiring plan, that there must be also a "transfer socket".
Do you have pictures, or descriptions, where the cable has been laid, or where I can find the transfer socket.
Hopefully on the weekend I can use a lifting platform.
Do you have tips, where I should look, to find the issue fast.
am i actually alone with this problem, or do others have these problems too?
It is very unlikely that the cable is broken, I bet the connector is corroded instead. Clean up all the connections with a wire wheel and give it a go. Clean both the wire connector side and the post side.
CRoger (01-29-2020)
I have allready replaced the cable, which is the red one in the picture. Right in the middle of this cable was a sharp bend, so some wires are broken in the cable. I can't believe that too, but the Connector where fine, like new one.
But you are right, thats the reason, why I am searching for the transfer socket.
I could be wrong but isn't transfer socker is just another name for a power distribution block next to the battery?
I think your best bet is to just follow the cable to see where it leads.
CRoger (01-29-2020)
Thank you, but you can see in the picture the power distribution block.
This transfer socket must be somewhere else...
I would like to know the location, before I start to investigate the failing cable.
