Where does this vacuum line go to?
957 CTTS.
Drivers side just above a pulley, is it broken? I just noticed it poking around the engine.
It's broken anyone got the part number and the routing of it. I'll check alldata in the meantime.
edit: found where it's connected. Appears I may have to remove the radiator hose to change it.
looks like the tape got loose and the other end got caught in a pulley.
So this is the other end. How do you loosen that connector?
I'm thinking that I'd go to the parts store and pickup a piece of vacuum line and rejoin the broken piece.
You'd need to pry that clip open with a screwdriver and afterwards get a new clamp and crimp it with a special tool to get it looking like that again. But You probably don't need to loosen it, plastic pipe just pulls off as the fitting isn't very tight.
TRINITONY (11-10-2020)
Anyone have the part number for that line handy? I looked at some diagrams and can't seem to make it out. Also any tips on changing it out, would be appreciated .
It's patched for now. Will check with my buddy at the dealer for the part number .
https://parts.porschemonterey.com/oe...be-94811066654
This should be it. You can certainly just use a piece if standard hose, that is the wastegate control line.
Thank you!
If so #15 above that I linked (948-110-666-54) splits between the two wastegates. It connects at the white joint to #17 (948-110-668-xx) the xx is because there are 3 versions, the -54 SHOULD be correct for an 09, but it may take some matching up or a vin to be sure. https://parts.porschemonterey.com/oe...pe-94811066854
You may need both. Getting access to the wastegates where the heat shielded hose section is will be a real PITA I suspect...
I was checking my line, and notice that the 2 of 3 clips on mine are broken and my line is mm from the belt, and no longer hold it to the corrugated tube well. Looking at the original damaged piece, this is close to the belt and looks like it wore through it possibly?
I am ordering some now, no one stocks them they have to come from Germany.999.507.800.40
