Has anyone installed mud flaps?
Are there instruction somewhere for installing the front & rear mud flaps?
If so, could you please post. I've done a search on several sites but couldn't find any.
Thanks.
Thanks.
Rennlist Lifetime Member
I just installed them last week - there were no instructions but it's very easy. You need to line up several of the holes in the flaps with existing screws under the fender lip. When you hold the up to the car you'll be able to see where they line up pretty clearly.
I did the install a couple weeks ago and although there are no instructions its pretty straight forward. Just line up the holes in the mud flaps with the existing holes in the fender liners. You'll have to use a utility knife and cut the notch for the fastener but there are outlines on the fender liner that will help. Just follow the lines. I would also suggest that you do not pre-drill the holes on the sides of the flaps. The self tapping screws will do all the work. Take you time, line everything up and its a pretty easy job.
Here are a couple pics:
