05 Cayenne S Won't Crank
Old 05-15-2019 | 11:31 AM
mscaptura's Avatar
mscaptura
2nd Gear
Default 05 Cayenne S Won't Crank
Hey everyone, found my Cayenne with a dead battery last night, threw my jumpbox on it and still can't get it to crank. With the jumpbox on I have electrical power but when I go to start and turn the ignition everything just turns off. Couldn't find anything like this described in a quick search so I figured I'd check to see if anyone had more insight before I rush off to buy a new battery. Thanks!
Old 05-15-2019 | 12:24 PM
NelaK's Avatar
NelaK
These cars take a lot of power to crank. Your jump box may not be able to provide enough amperage. They are also very finicky with their electronics. I think the best approach is to charge the battery overnight and then try again.
Old 05-15-2019 | 02:48 PM
dr914's Avatar
dr914
I agree, maybe the jump box itself is down on charge
Old 05-16-2019 | 11:06 AM
mscaptura's Avatar
mscaptura
2nd Gear
Thanks for the input guys. Jump box had a full charge but per the dash gauge it was only able to provide about 10-11 volts at best which I'm guessing wasn't enough to crank. Managed to get the battery out to have it properly tested and it certainly seems like that's the culprit.
Quick Reply: 05 Cayenne S Won't Crank
