Insight Into Mods to Improve a Manual 957 GTS
thanks..
Can’t be just 180ish for North America across three model years...can it?
Please see post #10 for info on how to remove the original shift ****.
The 997/987 shift **** is about an inch shorter than the 957 one. This helps shorten throws.
I always see that 182/183 build number, it’s usually associated with MY 09. Has anyone ever discovered other build numbers for 08, &10? I remember reading that only somewhere near 500 were built worldwide.
I've seen a number of 152 for 2008 in North America.
I don't think there were any manual GTS's for 2010. I think you could get the Transsyberia with a manual also and it had the 405 hp GTS engine.
If you want to at least swap your shift ****, the old one can be removed by clamping vise grips on the shift lever below the **** with just enough room to insert a open end wrench (I used a long 12 mm). Then use the wrench to lever the **** off. It takes a bunch of force, but it will come off. This is much better than trying to yank the **** off and hitting yourself in the face or breaking a windshield.
Was lucky enough to score almost new one on eBay.
Here is my installed 997 4S shift **** in my 2009 957 GTS.
Shame on PORSCHE, as, trust me, this is how our 6-Speed was suppose to come out of the factory.
I cannot believe how ad-shaped and plasticy the original shifter feelt in comparison. MUST HAVE MOD, GENS !!!
frederickcook87 (10-06-2022)
Awesome!
How does the shift throw feel compared to the stock ****?
Quite a different shifting experience for sure.
The 997 **** is slightly shorter, the throws are definitely more precise. No more rubbery feel. It feels much lighter than before, that was my very first impression.
The overall feel of the 997 **** with leather/aluminum finish vs the 957 stock rubber/plastic design is night and day and most definitely 997 perfect circular ball vs the 957 OEM oval shape. Just really no comparison. I should have done the swap the day I got my GTS. Just make sure you get a nice one, if you ever consider a swap.
Big thanks to OP for letting us know about this mod!!
v10rick (08-14-2019)
My interior is tan, probably next to impossible to find a used one.
Just did a part search at my favorite Pcar place...a new beige leather shifter/boot, is only $262.
I see part #997-424-075-01-FOV...remember, this is beige leather.
Don’ t know if it’s still a good number, or availability.
I will confirm, and update.
Thanks, but do you have the pn for a beige vinyl interior?
I’m searching under 06 911 C4S, lots of manual transmission shifter options...aluminum, carbon, and plain leather in lots of color choices. I assume that the FOV at the end of the part number designates the color, but I am not sure.
I’ve sent an email to my parts guy to confirm. If a stock item, I’ll probably just buy one, and take the chance that the color match is close enough.
v10rick (08-15-2019)
Excellent suggestion: Just did this. Here are my tools and it came right off. WOW :-))
So...just the **** itself is being prayed off? You do, or don’t remove the boot first, then pry the whole assembly(boot & ****) off?
The boot was relatively simple to unclip in my 993, when I did the shifter change on that years ago, just pushed down parallel to the opening...and out of the clips. Doesn’t seem like the boot slides down from the base of the shifter ball on the GTS...
more detail please.
thanks
