Bore scoring. I know it’s been covered already , but different question
Grab a 9v pp3 battery and make up some leads. Take the connector off the vvti solenoid and use the leads and battery to cycle them. So hold -ve on one spade connector and tap away at the other, then reverse. Should get a thuck sound if they’re free. I did mine every few months like this on my 05 as they were a bit sticky and made the car sound like a diesel. After regular flushes, oil changes and cycling they came unstuck and never happened again. I then did it as preventative maintenance.
I would like to check them out, as it seems unlikely that borescoring would not get worse after 13,5tKM
My P!G sat unused for over one year before I bought it, I have replaced all fluids, but i feel the oil system has some gumming. I would like to flush but it seems to be not recommended on these engines.
Look at the engine from the front. On each bank right in front of you, you have a black plastic dome about an inch and a half round, sticking out of the engine on a 45 degree angle, the connector is under the dome. You can’t miss them-the left one is about two inch below and and a bit behind the oil filler cap. They’re right behind the maf connectors.
Feel like a proper idiot now . Have seen them but not put 2 and 2 together.
Now off to find a 9v battery
