Need help finding replacement part
Old Aug 27, 2018 | 03:40 PM
hinchcliffe's Avatar
hinchcliffe
Default Need help finding replacement part
When I did the coolant pipe and fitting on my 957tt this breather line apparently cracked and seeps motor oil. How do I identify it? Anyone have a part number, I've been searching but can't find it.
Old Aug 27, 2018 | 04:43 PM
hinchcliffe
Found it, 948 107 249 53.
I'm going to try inserting a line into it instead...
Old Aug 27, 2018 | 06:30 PM
NelaK's Avatar
NelaK
If I understand correctly, that line is connected to the PCV valve which connects to the air oil separator on the valve cover. Maybe double check that those two are also working as they should?
