Going to do Valve Covers on an '03 CTT. What else while I'm there?
Going to do valve covers on my CTT. I changed the Coils, and noticed some oil in the plug hole, and at 106K figured Valve Cover gaskets should be done.
While I'm there, going to do Air Filters and the Torque Arm while I have the room. I'm also going to do the purge valve since a have a check engine light and I assume that hose is cracked.
Anything else I should do while I have stuff apart? I'm wondering about the plastic air hoses and which ones I should worry about? Any other suggestions?
