Questions about side marker light...
I was under the impression that this like was a turn signal. Apparently it is not which seem foolish is it can easily be seen by a vehicle that might be directly to my side.
I wonder why Porsche did not illuminate the mirrors with turn signals like in the Touareg. I feel it is a nice safety feature.
Now my question...any every rig the marker light to become a turn signal?
They are definitely turn signals (and my Cayenne even uses them to blink "hello" and "goodbye" at me
There must be a malfunction on yours. I would talk to the dealer about it (after having checked it again).
David,
I believe the only difference regarding the side turning signals is the standard color, which is white in Europe and yellow in North America. Check out the link below:
Matt
Matt
Although it is raining like hell at the moment, I ran down to my car, just to make sure that I don't write anything wrong ... et voilà it really does blink.
The confusing thing is that the link I posted above points at Porsche's US website! So maybe this feature is really turned off on the US-Cayennes and the website is just a plain translation from German, regardless of any country-specific specifications? But why would it have to be yellow in the US, if it isn't a turning signal?
My apologies, David, for being so ignorant.
Matt's right,, my S lives in the UK and has clear side lens repeaters that blink - when I remember to use them! Ps It's raining in the UK this evening also. Regards, Peter Delmar Hall.
Did the US versions have a "breakout" into the wheelhouse like here? Pursch says over this breakout thats a safety feature that allows others in a side/back position to see that the car turns.
When I changed my US model to clear marker lights, it came with amber bulbs. I kept it amber thinking they are turn signals and it's code to have the front signals amber. Now that I know it's solid marker lights, I'm changing it back to clear (with a slight HID tint to match my Xenons).
BTW, the "Bi-Xenons" is misleading. They are in fact one bulb with one filament (vs. the hi-low hallogen bulbs where you can see two separate filament). A mechanical shutter flips down to expose more of the lense. You can hear the shutter flip. Also if you take apart the bulb, you can see the shutters.
