Tail Gate Wont Open From Key Fob or Drivers Door
Morning All,
I have just purchased a 2005 Cayenne S and after going round it checking everything out i have found that the main tailgate will not open from the key fob or release switch in the drivers door, the glass section will open and also i can open it manually from above the number plate, the key fob batteries seem OK as everything else appears to work as it should.
If anybody has any ideas i would be very grateful.
sounds like the motor died or the fuse for that motor blew or water leaked in from one of the rear drain tubes that's partially blocked by debris and the blockage caused water to run into the lift gate motor. Could be something more technical than just the lift gate not opening... like electrical wiring issues. Also, the first sign of a nearly dead battery is the lift gate operating very slowly or not at all. This can happen even if the engine cranking speed is not slowing down. Most of these should show up in a search of the Cayenne 955-957 forum. Your Cayenne probably has 2 batteries... one under the driver's seat and one in the back cargo hold under the floor. If a previous owner replaced only the battery under the seat, the battery in the back could be dragging down the entire electrical system.
so which fuse/fuses do i need to check, is the lift gate motor behind the carpeted panel on the tail gate
I am hoping it is something simple so i will go down that route first.
Thanks Again.
To be clear:
You say you can open it by pulling on the manual release above the plate. That is "unlatching" it.
If you pull on that release and it doesn't open, it's locked.
All the button on the fob and the door do is unlock it. Not unlatch it.
He's saying you may not have power-lift on your lift-gate if that was not an option installed on your vehicle. I assumed that you knew that you had a power lift gate because you had seen it operating as a power-lift hatch and now it is not doing that. The owner's manual has a "fuse map" in it. Downloading an owner's manual isn't too hard if you do an online search. Used to be able to download it from porsche.com but looks like they have deleted owner's manual downloads for vehicles over 5-6 years old.
Do you have a button on the bottom edge of the hatch (when it is opened) that you press to close the hatch with the motor? If that switch/button isn't there, you don't have a power lift gate. Standing at the back of the Cayenne, open the hatch and look at the bottom edge of the hatch... on the 957 series, the black rectangular button is on the right side (passenger side) in the middle of the carpeted bottom edge of the hatch. The button has a hatch icon on it. The 957 power lift gate does not CLOSE with the fob, you have to press that button on the bottom edge of the hatch to close the hatch---that's a safety feature so you don't lower the hatch on a person by not seeing them when you press the fob button. With the power-lift option, the fob will unlock and open the hatch, but you have to press the button on the hatch to close it or you can manually close the hatch if you need to. The previous post describes how the hatch works when there is no power lift gate option installed.
From reading twest03's posts carefully at this point, I think there is a very good chance that nothing at all is wrong (well, other than Porsche's design, of course). Confusion between open vs. unlock, noise vs. no noise, etc.
I understand part of the confusion due to the difference between how my 2004S works vs. my X5. On the X5, when you unlock the rear hatch (with either key fob or interior button), you can hear the actuator, and the thing actually disengages the latch, clearly opening by a fraction of an inch. You then press the handle/button and lift it up. So for the X5, "unlock" does kind of open it if a fraction of an inch counts.
The Cayenne is the same except that unlocking it is completely silent, and nothing at all unlatches or moves when you "unlock" either with keyfob or interior button in the driver's door. So there is no confirmation / reassurance that anything happened. Adding to the mystery on my 2004 is the 2-button key fob design from hell, where lock and unlock are done by the same button. But if you did unlock it successfully, when you go and actually lift the hatch handle, the actuator will instantly move, unlatching it and allowing the hatch to be lifted.
Again on the Cayenne, holding down the rear hatch button on the remote will unlatch the rear hatch window. Yes, in this case, it does actually unlatch, not just unlock. So you hear a clear click, and the thing pops up by a fraction of an inch or so.
^^^ All of this is what happens on my 2004 S without power hatch or anything like that.
Thank you to everybody for helping me to clear this up, this is my first Porsche so i guess i am on a learning curve now, next thing rear parking sensors
Yep, I was similarly confused when I got my old Cayenne. Made worse by a weak remote battery and the 2-button remote. Also, coming from the X5, I was even kind of surprised that the window would open separately from the hatch.
I hope i have made the right decision as i keep finding things like the rear reversing sensors not working just two red lights and no audible tone when put into reverse and the centre LCD display in the dashboard goes very very dull when it gets hot outside, i have only had it a couple of days and already found these things wondering what will be next.
