Help please, How to remove the intake pipes from the throttle body?
Hi,
I used @Mister Quickie image, I've been trying unplug this without success, I don't want to break it so I didn't force anything, mine is still plugged to the pipe.
How to unplug it?
How to unplug it?
I saw your earlier post in Mr. Quickie's thread. I'm sorry, I wish I could help you, but I'm away from my Cayenne, and I don't recognize that type of connector.
Yes, use only your hands, do not use any tools on these connections. You have to squeeze with the right amount of pressure. Once you get it apart you will see how it locks together. Sometimes I spray a little bit of aerospace 303 or tire shine on the connections and it can help them come apart a bit easier. This works for other plastic and rubber connections that get stuck together too. It works similarly to how penetrating fluid helps stuck/corroded bolts.
Thanks guys, I will have a go later, I tried doing that before, but I was afraid that I could break it, as plastic becomes brittle with the heat.
I will order some aerospace 303 or similar product.
Oh, yeah, I see now. When you squeeze the ridged section it deforms the ring which should release the catch tabs on the female connector.
