2004 cayenne warnings
Hi!
Got some warnings every time i stop the car, it makes 3 bips when i turn off the key. If i then push the brake pedal it lights up and 3 warnings comes on the screen. Brake porportioning, air ride and low oil pressure.
The car works fine when i drive it, but i hate the biping sound every time i stop..
Anyone know what to do?
Here is a vidio of the warnings: https://www.youtube.com/watch?v=Lz_u...ature=youtu.be
i have fix the wires like in the link, this happens only when i stop the car and turn key off. 3/4 times i stop the 3bips comes. Then if i push brake pedal the other warnings comes like in the video.
new battery, but the problems are still there... every time i stopp the car the beeps comes, making me mad! need help.. i have fix the wirers under floor, 433 rele and battey...
Hhmmm, battery was a good idea. Your cluster may be bad. I have seen it a few times, especially with the low oil pressure warning. I think if you plug in another cluster, from a friends truck or used you can confirm it, you'll have coding issues and maybe other warnings but you'll at least see if thats what it is. Using the other cluster as a diagnostic tool not as a permanent fix. If thats what it is then you would need to find a new one (I'm to 100% if programming a used cluster even works) and have a indy shop install and program/code.
Fuel warning beeps when im low on fuel, when i had low fuel warning all the other warnings when i stop was gone... put some fuel on and the warnings when i stop was back...?????!!
