Coolant pipes - How to know if they've been updated?
Old 02-11-2018, 08:34 PM
95_993
95_993's Avatar
Default Coolant pipes - How to know if they've been updated?
2005 Cayenne S....not sure if the coolant pipes have been changed as it was not in any details from earlier owner.
Is there an easy way to tell if they have been updated? Should I be overly concerned? If they have not been changed, should I have them updated asap?
Old 02-11-2018, 09:02 PM
19psi
19psi's Avatar
There's a sticky right above called Coolant pipes A-Z
There will be info in there on how to check with a cell phone camera or borescope camera.
If plastic, they need to be replaced and the sooner the better.
Old 02-12-2018, 09:20 AM
PartsGuyGT
PartsGuyGT's Avatar
As 19psi mentioned, a boroscope would be ideal. I've been able to check by removing the rear engine beauty cover and using a mirror to check. If it has the metal ones you should see one of the tabs for the pipes. If not done, it's a ticking time bomb. BTDT
Old 02-12-2018, 09:54 AM
95_993
95_993's Avatar
Thanks. I will look at it and report next weekend
Old 02-12-2018, 08:33 PM
aftCG
aftCG's Avatar
Pull the plastic cover off and use a mirror. Real easy.
Old 02-13-2018, 11:08 AM
jwicker
jwicker's Avatar
Get a borescope on Amazon for use with your phone. It's a great tool to have around the house anyway.
I tried using a mirror and found it to be pretty hard to see anything. Maybe that was just me, but the borescope was pretty simple.
Old 02-14-2018, 04:14 PM
jeff spahn
jeff spahn's Avatar
If they haven't been done and you do them, replace the starter and thermostat while you are in there. Might as well do the water pump too.
Old 02-14-2018, 05:31 PM
mtnrat
mtnrat's Avatar
How many miles?
Old 02-15-2018, 12:09 AM
95_993
95_993's Avatar
Originally Posted by mtnrat
How many miles?
65K
Old 02-20-2018, 03:26 PM
95_993
95_993's Avatar
Ok, here's the pic. Let me know if you think the coolant pipes have been replaced. Hopefully I've zoomed in on the right area.
Old 02-20-2018, 07:46 PM
mtnrat
mtnrat's Avatar
Not very good focus. Looks like not. That can be a good thing as no coolant has got into the starter or torque converter seal. Here is what the aluminum pipes look like. The plastic is the hold down clamp at the back of the engine.
Old 02-20-2018, 08:14 PM
95_993
95_993's Avatar
Thanks Mtnrat. Yeah, the borescope was tricky to get focused, but I am thinking this is one of the last 2005's out there without the upgrade.
Old 02-21-2018, 02:10 PM
mtnrat
mtnrat's Avatar
Change them out ASAP. As in yesterday. They will fail and it will be soon.
Old 02-21-2018, 05:00 PM
95_993
95_993's Avatar
Agreed.
Old 02-22-2018, 11:24 AM
95_993
95_993's Avatar
Any estimates on what an Indy might charge for this?
Quick Reply: Coolant pipes - How to know if they've been updated?
