Replace entire center drive shaft, not just bearing on an '06 base
The dealer said the center drive shaft (Part 95542102015) should be replaced in its' entirety since attempts to replace only the bearing tend to fail.
Also while at it, the (2) exhaust brackets (95511122012) should be replaced as well.
The instructional videos online either only show the bearing area of the center drive shaft but not the removal/replacement of the drive shaft itself.
I can usually follow the Pelican photo tutorials well but didn't see one on this.
Is this an intuitive/easy job or does this require a tutorial?
Best
Julian
I purchased a rebuilt drive shaft and bearing, which the local Goodyear shop replaced.(2 hr. labor charge)
There was a core charge but excluding that the total cost was approx. $700 installed.
It worked perfectly for about 40K mi., until sold.
The V8 Porschephile
Lifetime Member
Lifetime Member
If/when I have to do this job, I plan on going the Lindsey Racing/Driftshaft Shop route. Looks to be bullet proof, and the price is right if you install yourself.
https://www.lindseyracing.com/LR/Porsche/955-0308-DS-AL.html
https://www.lindseyracing.com/LR/Por...308-DS-AL.html
When you are in neutral and hear the sound is the car moving ?
If the car is stopped when in neutral it might be the coils & plugs as others have said and not the drive shaft. Do the replacement of the plugs and coils first too see.
However there is even greater vibration while driving and the dealer said the bearing is worn.
Problem is I just learned you need this tool to do it *right*:
https://www.ecstuning.com/b-genuine-...l/00072196800/
Apparently an experienced mechanic can finesse it without the tool but that's not me and at $276 for a tool ... ouch!
Save yourself big $$ and avoid the dealer.
Best
Julian
ECS wants $537 for GKN but that includes the remounting bolts which are invaluable since they tend to rust/break so it's nice to replace those.
The $276 for the tool.
They do have free shipping though.
Do you sell a package of the shaft, bolts, and tool and if so how much?
The V8 Porschephile
See above as far as "what the dealer said..."
https://www.vertexauto.com/porsche-c...t-p-10389.aspx
It was not used for my repair.
That shaft bearing will cause a thumping sound right under your elbow if your arm is resting on the center console, and at first it will only do it when you're hard on the throttle.
The RPM of the shaft is only related to vehicle speed, not engine RPM. At rest in neutral the shaft is not spinning, so there is zero likelihood of it being that.
Even if your vehicle did have a bad shaft bearing, the dealership will not suggest or install an aftermarket product without a blessing from the fatherland.
