Boxster & Boxster S (986) Forum 1996-2004
My Samsung car charger won't fit in cigarette charger
Old 06-27-2017, 09:19 AM
Cbonilla
Cbonilla's Avatar
Thin piece of cardboard held on by electric tape on the charger plug. Make sure to leave enough bare metal to complete the circuit to ground.
Old 02-02-2018, 11:17 AM
shkeller55
shkeller55's Avatar
Originally Posted by paulofto
I bought 2 of these, works in my DD as well as my 986
https://www.amazon.com/Griffin-Power.../dp/B0042B9U8Q
That Griffin adapter actually matches the design called for in the manual that came with the 2015 Cayman I just bought. Thanks, paulofto!
Old 02-20-2018, 01:47 PM
Vampster 986
5th Gear
Vampster 986's Avatar
the early cars had a larger cigarette lighter socket than the later ones and are pretty useless with modern accessories which don't fit, I had the same problem when I wanted to add another socket to the other side and bought an old one that now only is really good for the cigarette lighter it came for and not much else. you are probably best to swap it for one of these https://www.suncoastparts.com/product/PK9X6LIGHTER.html
Old 02-23-2018, 11:37 AM
Bill in VA
Bill in VA's Avatar
Not ridiculous at all. Had same issue with a Verizon charger. I simply wrapped the charger with black electrical tape. It holds and you can't even see it. Can't recall off hand. It might be two wraps.
Verizon charger is pretty long so I had room to do this.
Quick Reply: My Samsung car charger won't fit in cigarette charger
