O2 sensor "behind cat" = before or after?
Hi All
I got following Diametric error code: P0140:O2 sensor behind cat. conv. Cylinder (4-6)
I replaced the O2 sensor at the driver side, the one that attached to the exhaust pipe coming out of the Cat. In other words: the sensor located between the Cat and Muffler at the driver side. I still get the error and wonder “behind” means ahead not after?
Does “behind cat” means after Cat or before ?
Thanks all
Thanks all
Hi All
Thanks all
Thanks all
The #2 sensor is located after the converter, downstream of the converter, further away from the engine than the #1 sensor.
The #1 sensor is located in the exhaust header just ahead -- upstream -- of the converter, closer to the engine than the #2 sensor.
IOWs you got the right sensor (#2 after the converter) but the wrong bank.
Macster - Thank you so much for the inor,So some reson I thought 1-4 was driver side? so all I have to do is repeat the same on the other side - got it . thanks again
BTW, unless a sensor fails shortly after installation I prefer to replace sensors in pairs, at least, and really if the miles are real big to replace all 4 sensors.
My concern is one has two sensors both with the same miles on them. One acts up and is replaced. The other though still has the miles and while not acting up could result in a difference in how the two banks are fueled because due to its miles has a slower response time to changing oxygen level in the exhaust gases.
In fact in January of 2015 and within the last month or two I had all 4 sensors replaced in my Turbo (at 132K miles) and in my Boxster (at 300K miles).
In the case of both cars just one sensor tripped the CEL but I decided that due to the miles and the importance of balance in the fueling of the two cylinder banks to have all 4 sensors replaced.
Macster- I am reading another post where you had commented on the same topic. I want to clarify something: per that post and the diagram it says "For the Boxster/Cayman cars this would make the #1 cylinder the cylinder immediately behind the passenger (USA cars, left hand drive)"
so in this light would't Cylinder (4-6) be the driver side?
here is the link to that post:
https://rennlist.com/forums/boxster-...er-layout.html
This assumes Porsche follows the Bosch handbook in this regard and I believe it does. I have not come upon anything that suggests it doesn't.
BTW, if you have the Bentley Boxster manual on page 02-6 at the bottom of the page there's a drawing of the engine's cooling system. The passenger side of the engine has the cyinder positions numbered 1, 2, and 3. The driver's side has the cyinder positions numbered 4, 5, and 6. To determine the front of the engine looks at items 1 (water pump) and 3 (T-stat).
Last edited by Macster; 07-10-2016 at 01:03 PM. Reason: Corrected auto-correct typos...
