Boxster Check engine light
My check engine light came on in my 98 Boxster. I hooked up to the ODBII system and get a code of P1123. To the best of my knowledge this code means that the lean limits at idle are exceeded. I changed the o2 sensor for that side of the engine but it still gives me the same problem. I also checked the fuel pressure and it seems to be in spec.
Can anybody help with some more causes for this code. ??
Thank you,
Luc Gooris
LGooris@yahoo.com
Thank you,
Luc Gooris
LGooris@yahoo.com
3rd Gear
what's the mileage of the car? Are you in California by any chance? (i can run an emissions history check w/ your plate #'s)
How does it stink @ idle from the tailpipe? Can you smell alot of unburned gas or is there no smell?
