Shifting Issues? May Be Time To Replace The Transmission Mounts! by Pelican Parts
Basic Sponsor
Old, worn out motor and transmission mounts can cause shifting problems because the drivetrain is no longer firmly held in its position. A visible sign that the transmission mounts need replacing is the appearance of cracks in the rubber of the mounts. The rubber will deteriorate over the years and need to be replaced, even if the car has relatively few miles on it. These mounts are also hydraulic, so if you see fluid leaking out of them, then that is also a sure fire way to know that they have failed.
The transmission mounts are fairly easy to replace. Replace them one at a time (remove and replace on one side and then remove and replace on the other side).
For Boxsters through '04 with manual transmissions, we offer a wide range of mount options:
Boxster Manual Transmission Mounts
If you'd like to walk through the instructions for installing, click HERE
Let us know what questions you have.
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
