IMS Reality
I have two Porsche from the '80's and a 2004 Boxster. I've found the build quality of my particular Boxster to be quite good. However, I'm sure your experiences are valid too. I have read various articles etc. that suggest Porsche significantly improved the overall quality during the 9X6 years. I know people with much more than 50K miles who have had much better luck than you, and of course there are some that have had worse.
As for the IMS, I think everything that can be written on it has. There are many hypotheses and each has its adherents. However, none seems to explain all the failures. However, if the car is 2004 or earlier, than we now know there are good options for servicing it.
The 996 and 986 are 50k miles cars. At 50k miles, they start breaking down.. rather the components break down. They're designed to make Porsche money. That's why I traded it in for a Mini Cooper 2 two weeks ago. Now I don't have to worry about the IMS imploding every time I turn the key.
Also, worrying about the IMS every time you turn the ignition is simply avoided by addressing a problem, which all Ferrari, BMW, Merc, Audi, etc. cars have, *BUT* without the need to rebuild the engine from 1999-2005. In fact if you did the retrofit with your clutch the cost was neglible, as the LNE bearing is not the only route. Or if you simply decided to do the IMSB only, it could be done for under $1,000 using a non-LNE IMSB. Point is there are nearly 400K perfectly retrofitable Boxsters and Carreras to choose from. As LNE have posted they'd sold over 10K retrofit bearings and the number that have still gone down are barely a handful. The IMSB is not the principal reason to avoid these cars. It's the over-priced parts and specialized labor but show me a Porsche vintage where that's not the case.
p.s.
I spoke to a Mini Cooper mechanic in Florida who had about a half dozen Minis in his shop when I visited, some appeared to be used for Autocross and the mechanic himself competed at the national level. He point blank told me to stay away from Mini Coopers out of warranty for many of the same reasons you cite against Porsche. They guy has Minis on the lift behind me and he's honestly telling me not to ever consider a used one unless the factory is footing the repair bills.
