Need help with a horn problem
Hi All,
Just recently my '99 Box's horn had been going off when I brake really hard an when going around tight turns. Also the horn goes off when I barely touch the center. any thoughts to a fix? Can I pop off the center cover without activating the airbag? I did the side panels ok. Any insite to this would be greatly appreciated.
Hi Laura. Yes you are correct. I searched the forums and found out how others fixed this. I took it apart and put foam in where the grommets are, giving the frame more resistance. Let's see how long my fix will last. If it craps out again I can now fix it in about a 1/2 hour.
