Boxster & Boxster S (986) Forum 1996-2004
$5 Spark plug tube removal tool
Old 01-28-2012 | 11:10 PM
sghokie's Avatar
sghokie
Default $5 Spark plug tube removal tool
I tried the transom plug method for removing plug tubes. I was able to get 2 out, but by that point the washers on the plug were bent too much to get enough pressure on the 3rd tube.
I went to home depot and found these 3/4 threaded pipe nipples. The bigger one is is about 2 inches and 1 inch for the smaller one.
A few turns into the tube really secures the pipe in tight and then you can use the tee as a handle.
If I was to do the job again I would probably get a cap to screw onto the pipe and then use a screwdriver to pry for the tube which has the hose in the way.
Old 01-28-2012 | 11:49 PM
logray's Avatar
logray
Hey a pipe nipple! Brilliant!
Where's ed and the tool he promised on Pelican when we need him...
Old 02-28-2014 | 06:23 PM
IndyLadder01's Avatar
IndyLadder01
Big thank you to sghokie. This method worked like a charm. I even bought the cap as you suggested. Made getting those front tubes out a breeze.
Old 02-28-2014 | 08:15 PM
DennisAN's Avatar
DennisAN
Last year I found a galvanized pipe cap was the perfect fit to drift in a new front bearing for a Mitsu. alternator on my Miata.
Heck a plastic pipe coupler is good for drifting in a new Boxster RMS too.....
Quick Reply: $5 Spark plug tube removal tool
