03-04 non-S avail w/ 030?
* stock class SCCA? or PCA? or???
Is there a reason you are focusing on 2003-4 vs 2000-2002? Sure the glass window and minor hp bump are nice, but not sure there are any other benefits, vis-a-vie autocrossing.
Yeah, SCCA stock class. All theoretical at this point as I'm driving a mustang in street prepared this year, but I've been driving ponycars for years and I'd like to try something different and go back to stock class. Yeah, the power bump is the main reason I'd focus on those years. Any reason to think differently?
I started out looking at Cayman S in A-stock, but the 'vette is a lot less money and is very competitive. The CS boxster seems overlooked.
Yeah insite, I'm thinking that is the way to go, too. Despite the cost of the parts, finding a "real" M030 car is likely going to be difficult and I'd probably have to deal with options I don't want on top of that. I'd rather find a car that had everything else I want and do the swap if I choose to. *If* I were to get one (planning to drive a Mustang in SP this year) I'll research the actual rates and list of changes I'd have to do for the swap. In stock class it's all or nothing as far as springs and bushings go, but one of the bars and the shocks can be changed regardless so it may more may not be worth it.
http://www.planet-9.com/cayman-boxst...t-project.html
...I'm about to load dual adjustable Koni inserts into my Cayman S struts.
The place to start on a stock Boxster are tires. I've found the 285/30 18 rear and 245/35 18 fronts in Kumho R-compound tires will give you the best life and grip for regional events. We got 100+ runs on those last season. If you're doing National Tours, you'll have to run Hoosiers in the same size. Those are expensive, very grippy but start to fade quickly after 25-30 runs.
Interesting... is that the case on all PSM cars (gen1, gen 2, Boxster, Cayman, etc.)? We typically autocross a '99 Boxster and a '07 Cayman S with PSM off but I've never seen the indicator light come back on on the PSM button after braking. So you're saying that it reactivates and is running in the background without illuminating the button light? Or turning off the PSM Off symbol on the gauge face?
The following functions stabilize the vehicle in
emergency situations, even with PSM switched off:
– When PSM is off, the vehicle is stabilized as
soon as one of the two front wheels enters the
ABS control range.
– When PSM is off and Sport mode is on, the
vehicle is stabilized as soon as both front
wheels enter the ABS control range.
One-sided spinning of the wheels is reduced,
even with PSM switched off, to enable optimum
traction on all drive wheels.
So apparently it is functioning in the background during those situations. I've had co-drivers who told me they thought there were some PSM effects happening even with it turned off.
Thanks for the info. Han!
Just to add, it has been recommended that you will be able to change a *single* bar in stock class starting in 2013. Generally the BOD accepts committee recommendations so I'd expect this one to pass. This could help the understeer and tire wear issues the boxster might have. See the Nov. 2011 fastrack for details.
I get 60-80 competitive runs out of A6s on my Camaro. Pretty much until the grooves are gone they work well. I have a hard time believing a 400lb lighter mid-engine sportscar will be worse, though I do have double wishbones vs. struts, so the camber curve is a lot more favorable.
It's counter-intuitive, but a properly set GT3 front sway bar reduces understeer in camber-limited Boxsters by reducing dynamic camber loss. A rear sway would do a better job reducing understeer, but I fear it would cause wheelspin. How well does Porsche's electronic traction control work, is it enough to make it worthwhile to change the rear sway than the front?
Full disclosure: I autocross a non-M030 '04 986S in SCCA BS; the only mod I made (besides tires) was to add a GT3 front sway bar and Tarrett droplinks.
sjfehr, I had the same experience when I ran a 35mm front bar on my car in stock. It definitely improved tire wear and grip for all the reasons you list. I wasn't sure a Boxster would react the same way. Good to know it does.
