Brake Light Issue
Brake Light Issue
Hi All,
Seems when i put my foot on the brake pedal brake light comes on.....as per normal but when i press the brake pedal hard brake light goes off. Seems to me the switch/sensor (if thats what its called) is set for when i just touch the brake pedal but not when i brake hard. The brake pedal is a little bit spongie and i do mean a tiny little bit, but anyone got any ideas or come across this before ?
Do i need to bleed the brakes and get rid of a little bit of spongieness in the brake pedal or do i need to replace the brake light sensor/switch. I am open to help and suggestions
I have a Boxster 2000S if that helps.
thanks in advance
thanks in advance
Hi Ray,
Sorry should have mentioned (made it clearer) i was talking about the rear red brake lights not the dash brake sensor light.
I replaced the pads about 6 months ago, and no issues with the rear brake light until now.
I will try bleeding the brakes this week and see if that resolves the issue
Hi All,
thanks in advance
thanks in advance
What proved to be a worn out switch was causing the same symptom in my 02 Boxster.
While you're there... You might want to consider replacing the clutch interlock switch and even the cruise control disable switch -- if your car is equipped with a manual transmission of course. The switches are not expensive. The hard part of the job is getting one's body arranged to get at the darn things.
Then it sounds like you need to flush/bleed the brakes. And if the car is equipped with a manual transmission and clutch then you should flush/bleed the clutch slave cylinder.
Sincerely,
Macster.
Here's the link to the brake light switch (from Pelican)
http://www.pelicanparts.com/catalog/..._pg1.htm#item0
