keyfob stopped working- Install alarm for 00 S and reuse keyfob?
The keyfob I inherited from the previous owner is out of sync with the boxster. I heard it costs $100-200 to have the dealer reprogram the key. Since I don't have an alarm (at least I don't think I do- how can i check?) and I need the remote reprogrammed, I'd like to see if it is possible to install an aftermarket alarm and reuse the oem fob? Anyone done this?
2001 Red Orient Boxster
My key fob is acting the same way. Just bought a 2000 boxster w 54000. No service manual and not sure what is has and what it doesnt. Both keys open doors but nothing else. How do you sync key fob.
look here for the manual: http://www.cannell.co.uk/Manuals.htm
for the remote you might be in sleep mode.
Use the search function, there are many thread such as:
https://rennlist.com/forums/boxster-...r-working.html
Yes, what is up with the remotes? On one remote I can lock/unlock the doors, but not the trunks. On the other nothing works, but the LED light works so I imagine the batteries are OK. As far as the alarm, you can't function it with remote. You probably have alarm as I know my Boxster has blinking, red light on top of dashboard and on radio when vehicle is locked. Not sure how to turn it off if it should go on. I know each remote has two batteries, one for functions and one for LED light. Are these remotes supposed to be in sync with module under front driver's seat?
2001 Orient Red Metalic Boxster
My remote has stopped working if I don't use the car for a week or so. I get nothing by it. After I drive the car however, the key remote works just fine for a while.
If the standby function has switched off unlock the driver's door with a key in the door lock. If you open the door the alarm will sound. If you leave the door closed and press the #1 button on the remote control the remote control function is activated again.
Check your car's owners manual. The page # varies but look in the index under 'remote' to find the page #. In my car's case it as page 18, starting with Key with Radio Remote Control.
Sincerely,
Macster.
