Interested
I am interested in buying a boxster. Prefer newer but want to spend 15k or under. What years are best? Also see ims failures. They haven't fixed that yet? Any advice??
For $15,000 or so, 2000-2002 model years are doable with 50,000-75,000 miles and clean body and interior. Add some more dollars if it's the S model. I just bought a 2001 red, standard Boxster for $15,400 with 54,000 miles and happy with it so far anyway. As has been stated so many times on here, drive the vehicle check it out throughly, and if it passes your muster, move onto PPI. I wouldn't worry too much about IMS if there are no oil leaks and it passes PPI. You will just drive yourself crazy. Warm motor up before putting revs into 5,000 + territory, change the oil often, don't lug the motor, and enjoy it as with a little luck the IMS will be fine. I look at buying a Porsche like being in the stock market. If it's going to cause you to lose sleep, then the market and the vehicle is not for you.
Now with the IMS are there fixes? and what should I expect to pay for that?
I currently own a 964 and just don't want to buy a car and then have to replace the motor.
Ironman 140.6
http://www.lnengineering.com/ims.html
I think it also matters greatly on how you drive your Porsche. For me, the Boxster is a second car and driven for pleasure only on nice days about 6 months out of year. I could be all wet and probably am, but it seems to me many who are having IMS problems track their Boxster. In manual, Porsche recommends no racing tires as the ultra high g forces will starve engine for oil. I don't see the Boxster as a daily driver either, but I'm sure many on here drive theirs to work every day and put tons of miles on it/year. I know some state garage queening Boxster may lead to premature IMS failure, and driving it will extend life of IMS. I don't know that anyone has the answer on why the IMS sometimes falis. All I know is that getting the LN IMS retrofit kit makes good sense when the time comes and IMS should be maintained like for example the water pump and serpentine belt. Pay attention to it and think about kit when the time comes.
If you plan on creating a "spec boxster" type car, you need to stick to '99 and earlier
If that's not a concern, I'd look for a 2000+ model year. These cars had upgrades in the interior as well as a small hp/displacement bump in the base cars from 2.5l / 201hp to 2.7l / 217hp.
If you can find one a 2003 would have a glass rear window that makes a nice upgrade.
Figure out color combos and options you "must have". My boxster didn't have heated seats.. After while, I wished it did (I really liked the top down driving feel). There were TONS of options available on these cars so it seems no two are really alike.
