Back fire at start up
As the title says, I have a 2001 2.7 that back fires thru the intake A LOT when cold. When the car heats up it still does it just not as bad. MAF has been changed along with ECU, Alarm module and lots of other stuff. Any ideas???
However, that the backfires occur when the engine is hot could be due to an intake air leak. Backfires through the intake most often (but not always) are due to a too lean mixture. Check the oil filler tube cap for a leak. The oil filler tube itself can crack/split and leak as well. Can't recall ever reading about one leaking so bad as to cause backfires, though, cold or hot.
Then a bad AOS could also be a suspect.
And what's lots of other stuff refer to?
Has the intake been messed with recently? Could someone have been at the engine and left a vacuum line loose? Or could one have broken and not been noticed? Were the coils/plugs changed recently?
Last thing touched is always suspect so the last thing serviced, like plugs/coils, could be a clue.
Sincerely,
Macster.
