2001 Boxster S Immobilizer problem?
Lurking on the forum for a while, but now hoping that someone can help with a strange problem on our 2001 Boxster S 6-speed. Car was running fine when parked in the garage about a month ago. But now.....
I've searched around in the archives, but I can't see anything quite like this. My best guess would be some kind of immobilizer problem, but any other ideas before I trailer it to the dealer would be much appreciated.
- The doors won't unlock on the remote, but that's not unusual after a long interval.
- The dash lights up, but the engine won't turn over
- The central locking doesn't operate via the dash switch
- The window switches don't work, but the glass does lower when the door is opened
- The front and rear trunks won't unlock via the sill switches
- The front trunk won't open via the fuse panel jump point
- The battery seems to have a reasonable charge - the headlights are fully bright and the convertible top operates at normal speed
- I have replaced the battery in the key remote
- I can't find any blown fuses
