2004 Boxster S transmission oil change
Good evening everyone,
As I tried to change the oil in my transmission this afternoon, I stumble upon a problem. The oil filling plug seems to be a 9mm DOUBLE square bit. All the information I found on the net talked about a 10mm hexagonal plug. Anyone has more precise information about this plug? My car is a 2004 Boxster S 550 Spyder edition.
Thank you,
Eric
Thank you,
Eric
Thank you,
Eric
Thank you,
Eric
Sincerely,
Macster.
Hi Macster,
The plug is not the ''triple square'' type used on the 5 speed transmission. This one seems to have two square. One of my friends suggested it might be as simple as a 3/8 socket wrench plug. What I will do is take a picture next time (in a couple of days) it goes on the lift and should find out for sure then. In the meantime, through my research on the net, I found this very instructive video for the benefit of all Boxsters. Almost forgot! my transmission is a manual 6 speed!
Eric
http://www.youtube.com/watch?v=VAl9g...ext=1&index=29
Eric
Hi Macster,
Eric
Eric
Ok the same Haznet wrench bit is listed in the digital manual.
If that's the not right bit then I don't know what the right wrench bit is.
Sincerely
Macster.
That's one scary video right there - I'm thinking I'm sticking a pinky finger in my tranny soon.
"life time grease" - see IMS bearing. What were these people thinking?
Hi everyone,
I finally spoke to a kind gentlemen at the company DBOX (they repair transmissions) and he told me the filling plug is on the driver side at about four inches forward from the end tail of the transmission. It should be an Allen plug. I will check and take pictures.
As far as your comment Alan, I agree 100%, I think it is good to spread the word out there for the benefit of all. On other videos made from the same business, they give more information about the problem and the solution. Also their advice, is once you find grease, to consider the rebuilt prior to failure. At this point, you might as well change the IMS bearing at the same time. (There is also a mod. available for this bearing)
Eric
Eric
This is what the Boxster shop manual calls out:
http://www.hazet.de/uploads/tx_d3mli.../2567-16_e.pdf
Sincerely,
Macster.
Sincerely,
Macster.
Hi everyone, as promised, here is the picture of the 2004 Boxster S manual transmission under the car.The picture shows the rear of the car on the driver side. I added one green arrow to show the location of the refill plug and an orange arrow for the drain plug. Both plugs were 10mm Allen. A word of advice: get an Allen socket of not more than 1 inch long to remove the refill plug, it makes it easier to fit the wrench in place without removing any other parts.
As for the grease, none for now!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
