Tire Pressures for track day?
I have a 2001 Boxster 2.7 and will be taking it on its first track day in a few days. I have PS2s on the car. 20517 F 25517R. Anyone have a recommendation on waht kind of cold pressures I should be running? What should I expect to see after a hot session?? Thanks in advance!
I'd start with the factory recomendations ( under th trunk lid) and add 5-6 psi. The engineers recommend those tire pressures for a reason. But they are always a bit conservative for the purpose of ride comfort. The additional psi will stiffen up the tire a bit and hopefully make it more predictable to break traction. But the only way to really get it right is thru trial and error. Drive it and see how it feels. Add or subtract two psi at a time and see how it feels untill you like the results. But Thats just what I used to do on the track. I'm sure others will have some great advise too.
David
David
David
David
For autocross, I've found the rear pressures to be pretty close to perfect already, but the front to be WAY low. Raising the front pressure helps considerably to reduce the understeer and let the car handle more neutrally. I run with my rear about 2lbs above spec, and front slightly higher pressure than the rear. [This is hot pressure, btw; I bleed air to maintain it.] I unfortunately can't recommend a track pressure, but leaving the rear alone and raising the front to match would be a good place to start, IMHO. Be aware, also, that the tires will heat considerably, and pressures will rise, too, giving you higher-than-street pressures as you start really pushing the car, which is desirable. Your instructor can help you tweak this, as well. You might consider adding as much negative camber as you can get in the front, too.
Most tires like, approx, 40psi hot. iirc, the stock pressures are 29f/36r? I'd start at least 35 all around and see where they are after your sessions.
If its your first track day, there are lots of things your mind will be on, but your instructor and others will be there to get you going in the right direction.
