How To Bleed a 99 Boxster TIPTRONICS
I have just installed a new water pump, can someone tell me how to bleed, i did not flush the coolant, it is a 99 TIPTRONICS, Thanks in advance, Vic
A real pain and frankly to my way of thinking strictly medieval.
There are rather inexpensive tools that will connect to the coolant tank opening and by which you can pull a vacuum in the cooling system -- I've been told by service techs enough of a vacuum the rubber hoses collapse -- then shut off the vacuum line and open a line that runs to a multigallon container of properly mixed coolant. The vacuum in the cooling system will cause the cooant to flow into the engine with no air pockets.
IIRC Mike Focke (www.mikefocke.com (?) or search for Pedro's Garage web site either of which I think has a section pages that describes the 1st technique and maybe offers links to the tool I mentioned.
Sincerely,
Macster.
